after recent software update my fenix 7 pro solar stop measuring HR from the wrist sensor, only works with HRpro band, can you help me with this issue? thanks
Hello 5024064
I am sorry to hear you are having this issue. For the HR not reading, I would recommend some initial steps:
If any of these are showing 0.00, the sensor software is missing. You can try reinstalling this using Garmin Express. https://www.garmin.com/en-US/software/express/windows/
If there is no change, I would also recommend trying a factory reset using the steps below, and try the steps with Express again.
If this continues, I would recommend you can contact Garmin Support as the watch will likely need to be replaced.
Thabks for the support unfortunately neither of the steps worked, I just talked to another person with the fénix 7X and had same issue after 18.14 firmware release, how can I roll back to previous software version until Garmin create a fix of current version. Also where can I report this release issue?
