Time zones glance on firmware 17.28
Why do you remove two time zones from the Glances on Firmware 17.28 ? Previously it was two alternative time zones on glances at once and it was very convenient. but now it is only one (stared/favourite) time zone. Could you please return back previous functionality or add an ability to display two time zones at once like it was before? Thank you.
Garmin Fenix 7x Sapphire Solar
Top Replies
  • Hello
    It is true, currently the Alt.Time zone glance will only show the single time zone. However, if you select the widget, you should still be able to view multiple alternative time zones.
All Replies
  • Hello
  • Yes, if I select the widget there are all time zones. But previously it was more convenient to see two time zones at once on the glance list. in my case it were UTC and Chicago. I need at least two button "clicks" to see second time zone for now. Previously it was just one click if Alt.Time zone glance at the top of the glance list. is it possible to add some configuration or settings to disable two alt. time zones at ones? Thank you.
