Fenix 7x inconsistent data!
I've had Garmin Fenix 7x sapphire solar and I use its open sea activity app, however, the scores are inconsistent. Measuring distance seems to be the main problem as I often follow the same route and what I get differs from the one day to the next. Also, recently, it often misses strokes, I mean it remains 0 in the respective screen, something which makes me count myself and, of course, does not give me a SWOLF result. I've installed 17.28. Any advice?
Top Replies
  • Hello
    I am sorry to hear you are having trouble with this. There are few recommendations to help with open water swim.
    • Sync the watch with Garmin Express, to ensure the watch has the latest satellite…
All Replies
  • Hello
    • Sync the watch with Garmin Express, to ensure the watch has the latest satellite data.
    • When starting any GPS activity, we recommend allowing for a GPS soak. For this, select the activity, and allow the watch to acquire satellite reception. Then wait an additional 2-3 minutes before starting the activity timer.
    • Use Multi-band or All satellites for GPS in the activity. Menu, Activities and App, Open Water, GPS
    • Since the watch will not connect with GPS when the watch is submerge in the water,, so you will need to use a stroke that takes your wrist out of the water, and you will want Every Second Recording enabled. Menu, System, Data Recording, Every Second.
    • You can also keep the water under your swim cap, or attach this to a floatee to keep it out of the water more often.
    Tips to Improve Accuracy of Open Water Swim Activities
