Garmin Weather Widget Nearest Weatherstation
Hi,
i have the problem that the next weatherstation near by me is at 2000m of elevation and i live at 500. so the temperature displayed is wrong.
Once i had the chance to fix another location, but after the latest updates the following instruction does not work anymore due to the missing setting "weather location"
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Settings.
  4. Select User Settings.
  5. Select Weather Location.
  6. Select Use Fixed Location.
  7. Select Fixed Location.
  8. Drop the pin on the map in the desired location.
  9. Select Set Location.
This screen will then show your set lo
see link:
https://support.garmin.com/en-US/?faq=Mxs4eRXzRdAYJ0h7yyWaj9
any other possibilites to resolve the problem?
Thanks!
