Hi folks, any recommendations for a screen protector that works for my watch? I am living in the Netherlands.
Thanks
Thanks
Hello olives_19
Garmin does not recommend using any screen protectors on the watches. This is the reason these are not made available for purchase from Garmin directly. A screen protector will use adhesive…
Its not common at all. Ive had several Sapphire watches and they're still pristine.
I would not say it is uncommon for the Fenix Saphire glas screen to get scratches. A lot of reports are popping up at leas since the fenix 6 era. I have a scratch on my saphire glas (or coating, whoknows…
Saphire glas is very hard, I would not recommend to add a screen protector because I think it is not necessary.
I have read 1000 posts related to sctraches due to the coating layer it has on top, so would like to prevent it but can’t find a good option with revies
Hello olives_19
Garmin does not recommend using any screen protectors on the watches. This is the reason these are not made available for purchase from Garmin directly. A screen protector will use adhesive to attach to the watch face. Unfortunately this adhesive can delaminate the display, damaging the protective coating already applied in manufacturing. This can also void any warranty coverage.
Fortunately as #Matthias# mentioned using a Sapphire glass is known to be very durable.
thanks, but I bought my watch in Japan and they sold screen protector branded Garmin in the official store.
what about the scratches everyone complains in the water coating? How to prevent that?
Why do you need a screen protector when you have the Sapphire? Isn't that like heavy duty glass?
Is not the glass the problem but the coating it has on top. Seen several posts of scratches
And as Laurie said, the screen protector adhesive itself will damage the coating.
I would not say it is uncommon for the Fenix Saphire glas screen to get scratches. A lot of reports are popping up at leas since the fenix 6 era. I have a scratch on my saphire glas (or coating, whoknows) as well. But the scratches you get are not impairing the usage in any way. They are so faint that you need the right angle to see them. Also the bezel will get scratches. It is an outdoor adve
ture watch, I don't really care too much, it shows that I use it
Even after getting a scratch on my saphire glas, I still think a screen protector is not necessary, since the scratch does not at all limit the visibility. If I had a screen protector on, I would not change it just for that faint scratch, so I would be in the same situation as without one.
(Sorry about the random emojis. It's a bug in Garmin's forum software).
Thanks! Exactly those scratches is what I am trying to prevent
