Today I received a notification that my snooze should be shorter than 30 minutes. I would like to set my watch to wake me up if it detects that I'm snoozing after 20 minutes. Is there such an option? Or is it not available?
I think you mean naps? Yes, in the nap glance you can set a nap timer.
Indeed, there is such an option in the snooze widget. It's a pity that you can't add a keyboard shortcut to navigate quickly.
Thank you very much for your answer, you helped me a lot!
Well, if you want a hotkey, you can set a hotkey for "timers", and add a 20 minute timer there. The downside is that a normal timer doesn't activate sleep mode (and who knows, maybe the nap timer helps the watch to recognize the nap).
One thing I loved about my Pebble was that it had something similar, where i could set up a range of times that I would prefer to wake up at, and it would go off when I was at my lightest level of sleep, so not in a deep or REM sleep stage.
