I have a Tactix 7 Pro whose altimeter is set to Auto Cal On and Sensor Mode Auto. I use it in a hilly, humid tropical forest environment.
When GPS is off and I calibrate the altimeter manually at a location with a known elevation by keying in the elevation, the altimeter remains accurate to within 2-3 metres when I go up and down with elevation changes on the order of 100 metres.
However, when I then activate GPS to save a location or track my route, the altimeter becomes inaccurate thereafter. It displays elevation about 30 metres higher than the actual elevation.
It seems that when I turn on GPS, the altimeter uses the GPS to calibrate itself and becomes quite inaccurate. In my case it always overestimates the elevation.
How do I prevent the altimeter from using the GPS to calibrate itself when GPS is turned on? The settings don't seem to allow me to do that.
Setting Auto Cal to Nightly doesn't fix the problem. What if I happen to use the altimeter and GPS at that exact moment that it happily decides to do its nightly calibration? I am sure that when I really need an accurate elevation, it will decide to do the night calibration without warning and I have no idea if the elevation is accurate or not.
