Hi all, I’ve removed an event from the calendar in Garmin connect but it is still showing in the race widget on the device (Fenix 7X). Is there a way to remove this from the device?
Hello Perilous
From what I am reading removing the race Event from the calendar should be removing this from the race Widget. Since removing this, have you tried a hard reset? If not, I would recommend…
Forerunner 165 same issue.
Since the Forerunner device is using another software version, you will want to report this concern to the Forerunner forum thread here: forums.garmin.com/.../forerunner…
I have the 7x and have the same issue... annoying asf
Since the Forerunner device is using another software version, you will want to report this concern to the Forerunner forum thread here: forums.garmin.com/.../forerunner-165-series
Hello Perilous
From what I am reading removing the race Event from the calendar should be removing this from the race Widget. Since removing this, have you tried a hard reset? If not, I would recommend trying this. Hold the Light button until the watch shuts off, as opposed to selecting power off. Then power this on again, and sync with the Connect app.
If there is no change to the Race day widget, please feel free to reach out to me via Private Message.
I had the same issue on my Fenix 7 Pro with an event I had added by searching for it in Garmin Connect. Based on advice from an older thread, I recreated the event (using the search again), synced the watch—which initially didn’t change anything—and then deleted the event again. This time, it disappeared from the watch.
In my case the original event on connect had been deleted (it was replaced by another with slightly different details)
