1) The weather widget stopped updating (refreshing) current temperature and wind power hourly if my watch doesn't connect to the phone. What I mean, my use case is that, I connect my watch to the phone at the morning and get weather data on the following 12 hours. After that I switch off my bluetooth connection to the phone and go away far from it. So widget and watchface show me only the first hour temperature (-27) all day (12 hours) and don't refresh it although the watch has hourly data. On 13.22 everything worked good as I need, but after next firmware updates I see this and I really don't like this experience. I want to see the current temperature on my watchface I can't and I don't want to keep bluetooth connection of my tactix 7 pro to the phone constantly or make it each hour!
2) Why does the waether widget show the current temperature is lower than the lowest temperature of a day?
3) Why did you remove an apportunity to setup the current location manually from the garmin connect? It was more convenient than now.
Will you fix it? or I have to stay with such a bad experience from Garmin?
