After the update to 15.74 the Fenix 7 is constantly loosing BT connection to the iPhone 14 (iOS 17). Tried deleting the phone in GCM and connected it again. However, still loosing the connection.
If you are noticing this concern after installing 15.74, please try the following steps:
Thank you very much. This helped immediately.
Many of my friends have this problem of unstable Bluetooth connection, why don't you fix it forever? I really wonder about the Garmin brand, why it works so poorly
Many friends have this problem, calling…
This was also reported as a Beta issue. You could try what was proposed by Mel_ODQA here: forums.garmin.com/.../constant-bluetooth-disconnects
If you continue having concerns after following the steps above, please direct message me or post the issue so we can gather some additional information.
Hi Cody,
While this helps, it’a not a long term solution. It really messes battery life on 13 Pro as it seems the phone never sleeps in this case. Fenix 7 battery life seems to be normal but phone’a one becomes abysmal.
I did all these things but the bluetooth connection is not permanent and the connection is disconnected, I am really sorry that you are not doing anything. Notifications still don't come often for my watch. I didn't have this problem before, but after the last forever, I have problems with Bluetooth connection and notifications.
Same issue here, iPhone 13, last iOS version, 15.76...frequent BT disconnect... Please Garmin solve the issue (since v14.xx...)
iPhone or Android phone? Multiple customers have reached out to me directly after updating their v17.xx iOS to report their Bluetooth connection issues have resolved.
Iphone 13 pro max iOS 17.2
I have this problem for several months, but Garmin did not fix the problem I am really sorry for this service
I'm thinking of using the Apple Watch because notifications are important to me
Since you have had the issue for such a long time, your watch will needs to be exchanged through Outdoor Product Support in your region if the steps Cody gave above did not help correct the issue for you. I am sorry your watch developed the issue. Select your country, then go to Support Center, and input your watch model. The contact information for your region will be at the very bottom if you search any topics in the Support Center.
