Trail Running In Segments With fenix 7
I am attempting to complete multiple trail runs but doing so will require me to drive to and from each trailhead. Is there any way I can track my “driving” time and my “running” time in the same activity, to establish how long this adventure took from door to door?
  • Just to add to this:  You can predefine the multisport activity or just start the activity prior to the drive and then split it into multisport after the fact in GC (Edit then scroll to the bottom to the 'convert to multisport' option.  Handy to use the Lap button to mark the transition but it can also be split based on time or distance (location).
  • You do not need to predefine a multisport activity specifically for such case. It is enough to use the function Change Sport (set up a hot key for it; look it up in the manual if you are not familiar with it), choosing Transition or Driving, while moving to the next part, and then using Change Sport again, and selecting Trail Run. You can repeat it as many times as needed.
    Another possibility is using the function "Resume Later" each time you stop the completed section of the trail, and then "Resume" at the start of the next part. The activity stats will show both the Moving Time (minus those pauses), as well as the Elapsed Time (including the pauses).
