I did an Ironman over the weekend and the garmin watch saved as one long swim :) a. What did I do wrong b. Can I cut into segments?
Use multisport activity for triathlon.
creating:
https://www8.garmin.com/manuals/webhelp/GUID-C001C335-A8EC-4A41-AB0E-BAC434259F92/EN-US/GUID-89CDBACD-34A6-40E4-BE62-50BE269E9A64.html
usage:
www8.garmin.com…
Actually it is easy to do in connect. There is an option to split an activity into multi sport and assign a sport to each segment.
creating:
usage:
www8.garmin.com/.../GUID-62DEE084-A8B3-40A8-9D4F-CC27B0699C3C.html
It's difficult if you didn't record it as a multi-sport event. If you want to attach your file to your post we might be able to make it happen.
Attach your fenix to a computer, then look for the activity fit file in the \GARMIN\ACTIVITY folder. Then...
Check out my open water swimming activity on Garmin Connect. #beatyesterday
Need your fit file. See 3 options in my previous post.
Check your email...
That's true.
I received your fit file. Since it wasn't recorded as a multisport activity, your best bet is to do what razmichael suggested...
As for what you did wrong, make sure you start your triathlon using the Multisport activity on your watch. I assume you normally do some training sessions (brick) using this, so you could test it before the next triathlon event. Mentioned earlier by Wolfindal
