My OEM watchband is finally wearing out. One of the little slots has now broken through which I can still use - just not at the desired tightness.
Any recommendations for a replacement band? Is it hard to replace the band?
Thank you!
Thank you!
There are LOTS of different watchbands, but for comfort this is very good (quite cheap also):
https://www.amazon.de/-/en/dp/B0928FGLXB
I've used that kind of band for a long time, easy to replace, easy to use, you get it just as tight as needed (velcro) and it's comfortable to wear.
Personally I'm interested also Garmins own (more expensive):
https://www.garmin.com/fi-FI/p/1056089/pn/010-13306-10
Link is to Finnish Garmin page, you should check your own region site...
Just check that the width (F7 22mm) is right.
Did you remove the pins to install this type of band? I have a few of this type of band that I have used with 5 Plus and 6 Pro, but the ends are too thick to fit between watch body and pins. If these Amazon bands fit without having to remove amd reinstall pins, that would be great.
The Yooside straps fit perfectly. Only the side without the plastic end needs to be threaded through.
Don't try to remove fenix 7's pins. I understand that it is possible but it's not the intended. Both straps are intended to be threaded. If looking for some other kind of straps use only quickfit clip type straps (same kind that original silicone strap has those clips).
Good to know, thanks! And I won't try remove the pins, pity though that none of my old fabric straps can be threaded through.
