Auto-backlight fenix 7x pro. It works like in a cheap Xiaomi phone. It looks like when it’s dark, it turns on the lowest level, but that’s not enough for me, I want a little more light. In Sony smartphones, the automatic backlight level is tied to the manual selection level. That is, if I manually select, for example, 70,
then in automatic mode the level will not drop to the minimum brightness, it will be higher and will be even higher if in manual backlight mode I select an even higher value and so on. I think you understand what I'm talking about. Can this be implemented in fenix 7x pro?
