I'm not sure when this started, but I'm seeing wild changes in my Fenix 7X SS barometric pressure.
Basically in the span of a few seconds, with the watch being on wrist or even static on a desk, the barometer reading will change enormously. For instance go from 1013 to 1024, then stay there for an hour, then suddenly go to 1003, then after a few minutes suddenly to 1013 again, etc. This is just an example, but if I look at my baro graph, I see basically a step function.
The altitude also changes massively, often going to negative altitudes.
This is in a stable environment, watch is static, baro ports are clear, no changes in weather outside (checking air pressure online shows it stable at around 1013), just those wild changes with the barometer.
What is going on? Is anyone else seeing this?
