How to see Cycling VO2Max from my Edge 530
There is no Physio TrueUp setting on the Fenix 7 SS.
I have read about Unified Training Status, and by that, i see that i would have to enable my Edge 530 to be primary as training device, since i mostly do cycling.
But if i commute to work, hike or walk, i use only my Fenix.
So, what would the correct setting be? which is primary? and if i set my Edge as primary, will it sync the past data and show my cycling VO2Max on my Fenix?
EDIT: now i see that Edge 530 might not be compatible with Unified Training Status... how to get the data on my Fenix then?
  • I think this answers your question. I run an Edge 830 and a Fenix in the manner below with no issues.
    What if I have a Device With Unified Training Status and One Without?
    The Device Compatible with Unified Training Status with act as the PTD by default. The device without Unified Training Status will still generate its own Training Status that will be visible on the device itself, but the Training Status on the PTD and in Garmin Connect will be the true Training Status. You will no longer see the option to toggle between different device's Training Status in Garmin Connect if a PTD is set on the account.
    What is Unified Training Status? | Garmin Customer Support
