Hello there,
Since 13.22, the wrist gesture switch in the Do-not-Disturb-Mode settings appears to be buggy.
It seems, that the seperate switch for wrist gesture on/off within the DND settings does not override the backlight settings for general use or during activity.
Example:
Wrist gesture setting for general use in system -> backlight -> general use set to ‚on‘. Wrist gesture setting in DND settings ‚off‘ & backlight setting ‚do not change‘
The intended behaviour is: When DND is turned on, the wrist gesture will be deactivated.
The actual behaviour is: When DND is turned on, the wrist gesture is still activated.
Can someone replicate this behaviour?
