Not able to delete sport heart rate zones
Hi,
Does anyone know the following issue?
I deleted all sport custom heart rate zones in Garmin connect. But with the next sync of the watch they would reappear on the watch but not in Garmin connect.
Then after a while, one custom heart rate zone pops up in connect again, but it is not possible to delete it via connect. On the watch, all default custom heart rate zones are then recreated for some reason.
Anyone else had that issue? Rebooting doesn't help, reset up the app and reconnect the watch doesn't help either.
Zones are defines in % of max HR since the BPM option was deleted in the past and the watch basically just switched to that -.-
  • Ok, after playing around, it gets a lot stranger.
    Deleting the sport zones in connect would not delete them from connect until entering them and leaving it right away again. Then the deleted one is gone in connect. When you have deleted it in connect, it won't be deleted on the watch. When you delete them on the watch, in that instant the deleted one on the watch pops up again in connect and with the next sync also on the watch.
    You can watch that behavior when you have the app open and look at the available sport zones while deleting them on the watch.
  • Ok, and it gets even stranger. If you set the Sport HR zones on connect to the same values as the general Zones are, the zones for that sport disappear from connect. On the watch, however, they are available and set to the same as the general zones. After that, there is also no possibility on the app to change them again until you do it/delete them on the watch.
