Programmed workouts in run modes don't work
This bug hasn't been fixed unless I'm missing something? So right now is everyone finding that if you want to do a programmed run work out, it's not possible as the timer, distance etc isn't accurate.. so any run track sessions have to be done manually where you manually press lap button for your set as if you leave it on the programmed one the data isn't right.
Any idea when this will be fixed, kind of major not being able to do programmed track sessions
