Hi,
after updating to 11.28 sw version I've problem with HRV recording with wrong result:
Someone else have same problem?
Hi,
No one have the same problem?
No problem here:
If a make a soft reset, can be a solution? I have to reconfigere all my settings?
If you hold the upper left LIGHT button until the watch turns off, then restart the watch (soft reset), you will not have to reconfigure any of your settings. And yes, it might help you - at least worth a try.
HTH
Thanks, tomorrow we will see
unfortunately same problem here after soft reset:
All my apps are broken on venu and Fenix 7 (and now also FR9xx devices) due to Virtual machine bug behind this
thanks, is there any possibile solution on the way?
over to Garmin - not holding my breath. Until this is resolved (and maybe longer) I'm moving on to apple development and going up that learning curve.
