With the latest firmware 11.28 and can't connect to a hidden Wifi SSID WPA2. The Garmin 6s pro on 25.10 I'm upgrading from connects to the same network fine. Is it a matter of logging a ticket or is this a known issue ?
Worked for me just fine.
The only problem I have is that it has to be DHCP while I usually only let devices with a dedicated IP address into my network. That taken care for: it worked.
Yes.
https://support.garmin.com/en-US/?faq=409ZW0MGUE7rnUixsyQoh5
Sry, didn't read the part with "hidden". So yes from me too. Won't work.
Yet works on my fenix 6s ?!?!? Doesn't make sense.
Doesn't make sense.
Not really. Let's face it: the possibilities to configure WIFI are rudymentary anyway to say the least. I can't find a way to even set the SSID name which would be prereq for connecting to hidden networks or even more a fixed IP or DNS.
Obviously that was possible with Fenix6? At least the SSID name? How? Directly on the device or with Garmin Express? B/o I have the feeling that GE > 7.15 has some limitations as for configuration - at least with me, I can't even configure and download maps using GE anymore since 7.16.xx. Not sure wether this is a firmware or a GE problem though.
