I have a Garmin Fenix 7S and I do not see the Jet Lag feature. Can you help?
Check that you have the latest update for Fenix 7 version 11.28.
Long press Up button >> System >> About >> Software Version 11.28
If so, then you can add Jet Lag Adviser to your glances…
The Jet Lag Adviser isn't shown in the App and on the website. I added the widget to the glances, but until now. Around 1 hr after installing the update, nothing is showing up in the app or the website…
It is not showing up in my app. I have the latest version.
I saw this on another post in the MARQ forum, but put into Garmin Express, it will want to check for an update. I had maps to update but was already on 11.28. Once the update was complete, I launched connect with from Garmin Express and it showed up there. Then I forced closed the connect mobile app, then opened and subbed the watch and now key lag advisor shows up
It is a 7S
Yes, but what system software version? Needs to be on 11.28
forums.garmin.com/.../fenix-7-system-software-11-28
and should match what is being reported on Garmin Connect
Software is up to date — Version 11.28
Sync with Garmin Express to get the update and sync across platforms (Garmin Connect Web and Mobile app)
I had same issue! Deleted Garmin Connect App. Downloaded it again and it’s now there. Hope it helps.
