After update 11.28, GPS positioning is extended,It takes one minute each time
I've also noticed a delay since a while back. It is not minutes vs seconds but rater 10-20s instead of 1-2s. I often get the yellow indication in a few seconds but getting green takes a while.
I use…
11.28 is a general release. Please post you findings in the main forum. Thanks.
+1 on Enduro 2. It takes up to 1 min. to lock on GPS. I use all+multiband in my outdoor activities.
I just reseted to default the watch (factory state) : it is much much better, not as quick as with 10.46, around 4 to 10 sec with Auto select (the default mode).
I’m also experiencing slow gps lock on F7SS. It can take up to 2min before I get a lock. There’re no tall buildings in my area and the sky is freely visible
Experiencing the same thing here. Was also on 10.43 previous and had the same fast gps fix of a few seconds. Now it's at least 35 seconds
I too have the experience. Longer time to acquire GNSS lock.
I have the same.
The watch had a 9.x version when I bought it a couple of weeks ago. GPS lock was instant when starting. After upgrading to the 10.46 version, still an instant lock. Now on 11.28 and it takes between 30 seconds and a minute to get a proper lock.
Have restarted the device several times, but no improvements.
I have no additional apps or anything on the watch.
Yep. Before this update it took about 20secs max not it can anything up to 50-60secs, sometime I have to come out of activity and then go back in!!!
I experience a similar behavior on two different type of devices: Fenix 7x Solar and and the Marq Aviator 2gen. Both run on the 11.28 version. Before the update the GPS lock took only 1- 5 sec max. Now akquiring the GPS signal can take upt to 1 min.
For me its the same before Update onliy some seconds after Update 30 Seconds to 1 Minute
