Outdoor Maps +
This thread is about the new Maps + feature available for the Fenix 7 / Epix 2 series.
My plan is to keep this OP updated with new information as we learn more.
I've already purchased a Maps+ subscription ($50/year), and played with it a little. Here's what I know so far:
  1. Maps+ is a US-only feature currently. No idea if Garmin plans to roll out other countries / regions in the future, or when that might be, but currently if you are not in the US, or don't spend any time in the US, then you can ignore this thread and the new Maps + feature.
  2. The maps can be downloaded with up to 6 different layer types, with things such as private land boundaries, satellite imagery (similar to the now-defunct Birdseye Imagery), and other advanced layer types
  3. You can decide which layers you want at the time of download, so you can omit certain unneeded layers to reduce the download and storage size.
  4. You can toggle layers on and off in each activity's settings.
  5. You can download everything (including the satellite imagery) directly from the Map Manager app on the watch! No need for clunky Basecamp software. Unfortunately, the watch is currently the ONLY place to download Maps+ stuff, there is no integration with Garmin Express, Connect, or anything else yet.
  6. You must have touchscreen turned on in order to change the region location/size you want to download.
  7. There is a size limit on each download, though it's not clear what it is. Sometimes I can download like 100 square miles at once, other times it won't let me download more than 9 square miles. As far as I can tell, there's no way to know how big of a region you can download until you get a "map size limit exceeded" error. For the most part, it always fails when I select a region at larger than 3-mile map scale.
  8. The plan can only be used by one compatible Garmin device but can be transferred to other Garmin devices.
  9. The satellite imagery works better than Birdseye - even though it pretty much looks the same, the watch does a better job of rendering it quickly, and it also is viewable at ALL zoom levels! Classic birdseye imagery only showed up at certain zoom levels, and was often slow to render.
  10. It's a bit buggy currently. For example, the size estimates are all over the place. It'll tell me it's 2.5GB for a small 1 square mile area, and then if I zoom out to 100 square miles it estimates 150mb. From what I can tell, the size estimate is not reliable at all, you kinda just have to download it first and then see what size it ended up. Also I've experienced a couple watch crashes while playing with the Maps+ in map manager, and while turning on and off layers in an activity.
  11. Some map layers (parcel, public lands, hunting units, etc) appear to download the entire state regardless of the size of the region you highlighted. For example, I only downloaded a small region around my house, but when I turn on the Public Lands layer it shows that layer for the entire state. I suspect that when you download multiple regions, it downloads a copy of that entire layer for the entire state, every time, resulting in way more storage space being used than necessary. So it might be best to only download your first region with all the layers turned on, and after than only include 1 or 2 layers (like Satellite imagery) in subsequent region downloads.
Here's a link for product info: https://www.garmin.com/en-US/p/893561
And a link to the support article: https://support.garmin.com/en-US/?faq=eEU6gvM2eX53qJBQD6bkn5&partNumber=010-D2098-00&tab=topics&topFaq=true
  • The POI map adds some extra outdoor Points of Interest. I don't know what the key is there, but here's an example.
    Basemap without extra POIs
    No POIs
    Basemap with extra POIs
    POIs
    Notice the lake itself and dam  at the south end are now POIs. I don't know how useful this is though.
  • I'm still having the same issue downloading Maps+ maps... download status sits there at 0% indefinitely, no matter what I try. Been happening for a few days now. Tried several reboots, tried clearing the download queue, tried several different wifi networks... no dice. Weird because it was working perfectly for the first few days.
    Probably I'll wait until the next alpha/beta firmware comes out and see if that changes anything, before I reach out to Garmin directly about it
  • this is a tremendous post, thank you so much for doing it. i suddenly have an interest in this and this thread is helping me quite a bit. so, after 4 months and a couple of fw updates to the watch, how are you liking outdoor maps+? worth upgrading? my primary use is for hiking in national and state parks so i assume mostly satellite imagery with more detailed contours
  • For only $50 a year it's worth it in my opinion, though honestly I haven't used it a ton really. Part of the reason I haven't used it much is because I still have a ton of legacy Birdseye Imagery loaded on the watch, so I haven't had a reason to need that from Maps+.
    But now I've just bought an Epix 51mm Pro, so I'm going to start using it a lot more often. I haven't decided yet if I'm going to buy 2 subscriptions, or just transfer the subscription off the Fenix and onto the Epix.
  • For me, the jury is still out. There has been some improvements since I started this thread. I haven't ran into stuck download issue lately, so hopefully that's gone. Also, without much fanfare, Garmin expanded satellite coverage to the whole world as far as I can tell. At least it worked for me in Europe in April/May pretty well. This obviously only applies to satellite maps, not other layers for now, but it's very important for me as I travel a lot.
    The interface has also been improved somehow, but it's still missing more options for download. I want the ability to download maps for specific course I created in advance. I would appreciate clearer explanation of which layers will actually be downloaded. It's still somehow cumbersome process to download the map for the area I want. I do appreciate a ton though that it can be done from the watch on the go.
    For me, the main reason I am still hesitant, is I just find I don't use most of the layers that much. I like the more detailed contours the most and keep those on most of the time (though there are cases where there is just too many contours on the map). Satellite maps are great in theory, and there's definite coolness factor to them, but for a quick glance, even on my Epix with AMOLED screen, the standard maps have much better contrast so I tend to prefer them for on trail navigation. But things obviously change rapidly if I move off trail or do some geocaching. They'd make great use case for backcountry multi-day trips, but downloading all the satellite maps for week long backpacking trip will be a hassle. USGS maps are cool and have almost as good contrast as the default maps, and occasionally trails and features that are missing on TopoActive maps, so they make a good alternative at places. The other layers don't really do much for my use case of mostly (long) hikes. It's nice that's it's easy to switch the layers on and off pretty quickly though.
    So I think the value proposition here really depends on your use case. If you are in the situation where you will use some satellite maps or USGS a lot, than it absolutely makes sense to keep the subscription, at least if you're mostly in the US. I am kind of thinking there will be more improvements by the time my renewal comes around and that will tip me into the yes category, but if my renewal came now, I would be somehow torn.
    Than again, I think it makes even more sense now than it did 3 months ago to give the subscription a try for a year and see for yourself. $50 really isn't that much.
  • Also, without much fanfare, Garmin expanded satellite coverage to the whole world as far as I can tell. At least it worked for me in Europe in April/May pretty well.
    Oh wow, that's the first I've heard about that, that's great news for a lot of people.
    So in the 2 hours since I last posted in this thread, I made the ultimate decision to cancel my maps+ renewal on my Fenix (although the subscription is still good for another 6 months I think), and activated a new subscription on my Epix.
    90% of what I use Maps+ for is the satellite imagery. Like jsla7527 said above, I also haven't found a ton of uses for the other layers yet. And now that I have an Epix, I can't imagine ever wanting to use satellite imagery on my Fenix again... it works, but it just doesn't look that great and it's a little hard to make out what you're looking at.
  • Oh wow, that's the first I've heard about that, that's great news for a lot of people.
    I saw you can actually buy OM+ now for example in Czechia: https://www.garmin.com/cs-CZ/p/893561. The price still translate to the same price as in the US though and you're only getting satellite maps for your home area. I suppose this is true for other countries as well. And since garmin sells them abroad, they should support them as well.
    Personally, I would probably just transfer the maps, because I am curious how the process works, but it's kind of cool to be able to compare the two devices too.
  • Can you download aerial photos for Greece??? OM+ It's not available  for my country, can I buy subscription with address of another country and download maps for my country???
  • It's great news that Garmin have included the whole world again with satalite imagery as they did before with BirdsEye, however the price is £50 (65 USD!) that's pretty expensive for just satalite imagery compared to BirdsEye at £25 until it was discontinued.
  • I agree. They should have 2 subscription options for this - the standard $50/year one, and a $25/year one that only includes satellite imagery.
