Anyone know how to get this screen on the Fenix 7x Solar?
I did create a power guide on Garmin connect, and I find it in the watch.
But when I launch the plan I don't see the areas to respect during the outing.
Thanks.
Thanks.
This screen is from an EDGE device.
Yes indeed but it does not appear on the Fenix 7x while it is compatible with the Fenix 7
Power guide is compatible, but where do you read that this screen is compatible?
The map is 100% from an edge device and looks different on a Fenix. I would be surprised if this screen would appear 100% this way on the Fenix
I would like to at least see the power to follow along the output. In fact, it may not be the same screen but the data that says how much power to drive.
I have the same problem. Maybe we can change some setting?
If you have any suggestions?
Or maybe a modification with Garmin directly?
I called garmin not solved yet.
We have to wait for a fix then.
Tomorrow morning I call them one more time. I tell you something tomorrow in the late afternoon
This is the Garmin answer
“I am contacting you regarding your request regarding the operation of the Power Guide function on Fenix 7,
We have carried out some tests, the view in prew view is not shown in the data pages that it will be able to display on the device while the activity concerning the splits is carried out,
But it will have to, first of all it will have to navigate the path in power guides then the splits will appear with the preset series previously in configuration.
It may be clearer to you when you go to fully navigate the route in power guide configuration.
Unfortunately I don't have a vision to show you with a video or a photo but you can check the functionality in business yourself.”
