The data after wake up seems to be incorrect. Look at the pictures. Total is 20, lower stress 1 hour and 13 minutes. If you check the graph in detail, you can see that the time in the lower stress is 30 minutes max. Thank you.
Interesting. Have you tried seeing the graph in landscape mode and adding up all the minutes? There's also some blue bars that slightly exceed the rest limit. Could they have been recorded as Low but displayed as rest?
They could be ... maybe. After installing 10.43 version the stress score seems to be higher than I have had before. With 10.44 version is still the same.
