As you can see here
what thy mean these numbers? Why +134, -65?
As you can see here
I never got this either :)
will keep an eye out here for an answer.
isn't that over the recording period (24 hours) body battery gained 134 points but lost 65 leaving 79 from the period yesterday .?
If you check in GC, it will be clear. Body battery, like other batteries, goes between 0 and 100 (%}. Over the night, body is charging. During the day and workouts, discharging. It could charge a bit during the day if you relax, do nothing or take a nap.
Confusing part is +134. I've never seen that. In my case positive or negative number is always below 100 but I always check with GC. Just checked in both, and numbers are the same.18/100, +53, -61. Not much body battery left after the run :)
It may be that the scale in Connect goes down to 0. In the widget on the watch, it goes down to a minimum of 5. This has always been the case. So I could determine it since the introduction of the BB so far on every watch of the fenix 6/7 and tactix.
I remember someone posting this as a bug before, the number should not be greater than 100. Phone and Web app should show something different.
It certainly can be , if you recover over night you can easily hit +70 a little power nap in the afternoon gives +40 so you have +110 for the day. Same with negative
Little powernap with +40
i have never heared about +40 in an hour
No bug here. It works in the same way as the as the Elevation Gain during your activities. You can reach an elevation gain much higher than the maximal elevation you reached, if you did several ascents and descents. Exactly the same situation with the Body Battery - have a mixture of some relaxed and stressful periods during the day, and you can easily gain far over 100 points.
