Hi Garmin!
I have a Tactix 7 Pro with the latest software version (9.33) installed.
Today I faced the following bugs for the first time.
1. When swimming in open water, the track was not recorded:
2. When starting the activity "Hike" the clock was set to pause and no further action took place.
Both problems were solved by rebooting the device.
In addition, the developers never deigned to fix a problem I mentioned back in May, which was absent in the previous generation of watches. It is the lack of possibility to switch the language to English (for the case when any other language is set). In order to reproduce it, it is necessary to go to the menu "Sensors" and try to rename any sensor - it will be impossible to write text in English.
