Power zones chart is messed up for all running activities with RD Pod on few recent FW versions. Sum of power zones times doesn't correspond with total activity time. Time in zone 5 is completely missing!
Hey Chris, I am using the GCM App on iOS, but on Connect Web its the same.
Zone 5 for example is shown >230W (which by itself seems really wrong - i did a easy aerobic run with of 1,5h) - i had an average…
Hi Chris!
I use GC Android and the problem is also in GC web. Zone 5 chart seems not working completely.
If you get lactate threshold after run (or do a LT test) with RD Pod or power compatible chest strap, you also get threshold power. After that, the power zones are counted from TP as you can see in zone…
I have had the same problem with 9.33 - completely off.
Thank you for your reports. I am sorry there is an issue.
- Are you seeing the issue in Garmin Connect web, your Garmin Connect APP, or Both?
- Are you using the Android GCM APP or the iOS GCM APP?
Zone 5 for example is shown >230W (which by itself seems really wrong - i did a easy aerobic run with of 1,5h) - i had an average power of 285 W but no time is shown in that Zone.
Hi Chris!
Since my zones are obviously also wrongly set, I don‘t really know how to setup my zones correctly or determine my Threshold Power. Is there a test to follow or how did you set up the Zones?
If you get lactate threshold after run (or do a LT test) with RD Pod or power compatible chest strap, you also get threshold power. After that, the power zones are counted from TP as you can see in zone settings at your profile.
Alright, thank you, I will try this Test.
You're welcome.
Still have this issue in 9.36 on fenix7s with HRM-pro.
- Yes, both, I'm using iOS GCM APP. And the power zone chart in watch after a training also have this issue.
finally got to do one lactate threshold test on a flat (after a lot of trail runs) today, and it worked. thanks once more.
