How do I connect 2 watches to my Garmin Connect account without doubling everything?
I have a new Fenix 7 and I’d like to connect my old Fenix 5 along with my Fenix 7 to my Garmin connect account. I’d like to wear both simultaneously to compare the GPS distances and compare the HR data etc. but I do t want to return from a 6 mile run and have my Garmin Connect account t think that I ran 12 miles or that I did two 6 mile workouts and count that towards my steps or my training status. Is it possible to do? And how can I make the Fenix 7 the watch that is primary and counts towards training status and the Fenix 5 still be able to upload the data to look at it in my Gatling Connect account? Thanks.
  • I'm not sure if it's possible what you want but in Garmin connect, when you click on device, scroll down, you will see option to make it as preferred activity tracker.
  • It’s not possible to do exactly what you want but you can open a separate GC account for one of the watches. Ensure that watch is removed from the other account and only exists in the second account. Add each account as a connection to the other. When you want to review the data open the activity in the account you are not logged into then select to compare the activity in the account you are logged into.
    Note, you can only log into one account at a time in GCM and GCINTERWEB.
  • I agree that the best solution here is to create two Garmin Connect accounts. Setting one device as a preferred activity tracker won't stop your runs (and related stats) from doubling up if you record them on two different devices (EDIT: connected to the same account)
    I mean, I know what you meant, but if you want to log into two accounts simultaneously, there's a bunch of ways to do it:
    • (website) on the same computer, use 2 browsers (e.g. Chrome and Firefox) or use the same browser with one window in incognito/private mode and and the other window in normal mode. If you have a computer, this is would be your best bet imo, if you want to compare two activities side-by-side
    • (website and/or app) use 2 devices, like a tablet and a phone, or a computer and a phone
    • (website) on an iPad Pro, use Split View and use 2 browsers (e.g. Safari and Chrome), or 2 Safari tabs - 1 in Private mode and the other in normal mode
    To be annoyingly pedantic, you can log into one account per device (for the app) or per browser instance (for the website))
  • Thanks for putting me correct; there are indeed workarounds to get two separate accounts open but
    The easiest way to do it is to open one and choose to compare with the other GCInterweb either within one account or two connected accounts.
  • You're right, that's a lot simpler (and more useful.) Sorry for being obtuse!
    (I will say that the comparison feature doesn't have *all* the stats and detail that the normal activity view does, but it's probably good enough in the vast majority of cases.)
  • There is a setting in Garmin Connect so activities do not auto upload from other watches.
    Its in Device Settings
    That way you can True Up without dupes. in GC
    Would you also have to disable Physio TrueUp in this case? Seems like otherwise you might get double intensity minutes, steps, etc., unless the feature is really smart.
  • It seems to workout as expected, certainly any activities with steps. intensity are not double counted.
    I keep TrueUp on everything except my Primary Tracker where its disabled.
  • Interesting, thanks! I don't know if this would work for OPs case, since they want both sets of activities on GC for comparison purposes. But it sounds pretty useful if you have two devices.
