TL;DR - Looking for information on the thickness of the 47mm top case o-ring gasket
I was having lunch earlier today when my 7X SS started vibrating and showing Assistance Alerts one after the other. After playing around with things trying to figure out what was going on, I realized it was acting like the power button was stuck on. I suspected perhaps it was moisture ingress, so I opened up the watch to investigate. Sure enough, there was a small amount of water inside the case and the power button also had a drop of water shorting out the switch.
In the course of opening the watch, I discovered where the water was coming in. The upper sealing surface was slightly wet with small droplets and the gasket that should be in the groove on the underside of the watch face was not there (!) I guess someone must have messed with this watch before I received it, as I also noticed other signs that someone had been inside it.
Anyhow, I need a gasket for the watch and measuring with calipers it appears to be a simple o-ring type measuring between 47mm ID and 49mm OD, however I'm not sure what the height should be for this watch. I'm fairly certain that 1mm thickness is too much and that Garmin used something smaller like 0.6mm or 0.8mm.
Does anyone know the height of the factory o-ring gasket? I could probably measure the lower gasket and its groove depth, and base the upper gasket on what I find there if I have to. It would be nice to know for sure from someone who has an intact gasket though, since the ability to seal properly depends on how tightly compressed the gasket is when the watch is closed up.
By the way, this isn't a warranty issue. It's a second-hand watch and was dirt cheap. It works perfectly now that it's dried out completely, of course. I just need to install a fresh seal to keep it safe moving forward.
If any of you have been inside your 7X and know the gasket thickness it would be a great help. Thanks!
Eric
