Hi, can anyone tell me if the Fenix 7 can tell you your location in lat/long or GB OS 6 fig grid ref. I’ve found how to change the data set but can’t find anywhere on the watch that actually tells you where you are. It’s not in maps or navigate?
You can add a data screen to an activity that gives you lat/lon information. Haven’t seen anything for OS but did you look at ConnectIQ data screens?
Yeap
Hi you can change one of your data fields to display either your current grid ref as either your selected Format eg British National Grid or as Long & Lat, when you go into settings for an activity such as Hiking & select change Data fields under the Navigation Fields Location shows your current grid as which ever format you have set in your main settings and there is another option to select Lat/Long, hope this helps
