Hello,
Just installed beta and HRV is missing from health Snapshot.
Did a few severval tests and HRV was never measured.
At 7.35 it worked well.
Thx for fix.
Hello,
Thx for fix.
I am having the same Issue with FW 8.13.
Same here on 8.13, was OK on 7.35, have performed a Hard Reboot
I wrote about this issue in the Beta 8.13 release thread. There must be something kicked up.
Thank you for this report, we have documented this issue on our side and we are working on a fix for this issue.
Same here on the Epix 2
Glad to hear that a fix is being worked on. I would just add that it was hit or miss in 7.35 as well. The main change that I have observed in 8.13, in addition to getting no HRV, is that the screen remain on for the entire snapshot reading. In 8.13, it was dimmed after about 8 seconds, I think, and switched off with 35 seconds remaining after which there was no notification of it's completion. I do have a concern that a screen like that being on for 2 minutes, nice if I prefer it and choose it, can lead to burn in.
I want propose that the appropriate default should be to be dimmed but particularly if it is turned off, which should be configurable, there should be a notification at the end, that the test has been completed.
This is on Epix 2 in Glance mode
Same issue here and add at the end of the snapshot 2 minutes the watch jumps to looking for inreach device. inreach device is turned off and has nothing to do with the snapshot. Have to monkey around and backspace every button to clear the inreach screen. Generally can't even see the snapshot screen.
Same for me. Worked ok on 7.35, but not with any betas later than that.
