I’ve followed everything garmin has recommended the fix the stroke count problem but my 7x has never detected a single stroke. HR works fine but it tell me I’ve burned 0 calories. My 945 worked flawlessly. 1000 bucks for a junk watch.
I am sorry there is an issue. Since you noted having already done all the troubleshooting possible and you are aware of how it should work having used a FR 945, please return your watch as defective back…
It depends on what your core issue is. If your issue is no swim distance being recorded on a Pool Swim, then you would have been put on the tracking case. There is already a thread for the issue that will…
I am sorry there is an issue. Since you noted having already done all the troubleshooting possible and you are aware of how it should work having used a FR 945, please return your watch as defective back to the vendor. If beyond the return period, please reach out to Outdoor Product Support in your region to warranty exchange your watch.
Why are you telling me to return it when someone else put me on an email list to let me know when you have a solution when I called in today. Returning it shouldn’t be a solution, not releasing a defective product for a thousand bucks should have been a priority
It depends on what your core issue is. If your issue is no swim distance being recorded on a Pool Swim, then you would have been put on the tracking case. There is already a thread for the issue that will be monitored and updated.
Right that is the problem I described having…
Thank you for confirming. I am locking this thread since there is already a main thread for the issue.
