Hi all
Is it possible to select a particular portion of a region to download?
Ie I do not need the whole European map. Is there a way to narrow the selection somehow?
Thanks
Hi all
Thanks
Is it possible to install two regions? Europe All is to big. Only one region is not handy, because sometimes I travel to other region, so two regions would be perfect. Only 16GB storage on garmin fenix…
Actually in Garmin Express I had the option to narrow it down! Unfortunately it gave an error as soon as I tried to install that portion of the map but it was possible. Try plugging it in your computer…
Europe is broken down into East, West and Central in Garmin Express, depending on your watch and space available, you may have to deselect Europe - All to remove and then add Europe - West or whichever…
Hi, only map regions can be downloaded meaning country level selection for download is not available.
OK. Thanks a lot
Actually in Garmin Express I had the option to narrow it down! Unfortunately it gave an error as soon as I tried to install that portion of the map but it was possible. Try plugging it in your computer and work your way through Express. Maybe it does work on your watch.
Europe is broken down into East, West and Central in Garmin Express, depending on your watch and space available, you may have to deselect Europe - All to remove and then add Europe - West or whichever one you want.
Sorry for the misleading answer, I wasn't aware of Garmin Express has the option to see multiple packs for Europe...
Is it possible to install two regions? Europe All is to big. Only one region is not handy, because sometimes I travel to other region, so two regions would be perfect. Only 16GB storage on garmin fenix 7X is terrible idea... how much did they save manufacturing 16GB instead of 32GB? 5 eur?...
