I have a 7S, should I be recharging when battery life drops below 20% or is it ok to let it run below 10%? Should the battery be treated like the iPhone battery? Obviously this is more an issue with the 7S as the recharging is more frequent.
Check https://batteryuniversity.com/
In short, lithium-ion should not be charged to 100% or discharged and left like that for long period of time. To prolong life of li-ion batteries, don't discharge bellow…
Bottom line, question was how to prolong battery life. You don't have to follow 40 - 80% rule and it's ok to charge/discharge from time to time. Personally, I'm just charging when drops somewhere below…
I don't know why are you arguing?! We are talking here how to prolong battery life not how much watch cost. Just to quote you "You can charge yours any which way you like" ;)
And no, charging…
It is good that Z has remined us about the science of the Li-Ion battery and how best to charge it. That does not mean I won't use the full cycle and at times let it drain and then fully charge it, because of some use reason or just convenience. But if possible, I'll plug it in at 40% and try to check it in 30 minutes and see if its at around 80 and unplug it. Again, my Fenix 3 HR that I wore for almost 5 years was severely depleted on how long the battery would last.
I found this quite interesting. It doesn't say what percent to start and stop charging, but it recommends periodically to discharge the battery completely.
Pro-Tip: After every 30 charges, allow your lithium based battery to completely discharge before recharging. This helps to avoid a condition called digital memory. Digital memory can mess with the accuracy of the power gauge of the device you’re using. By allowing it to discharge completely you will allow the power gauge to reset.
This seems to support both arguments about when and how to charge if used in conjunction.
To be honest, I think this could be a valuable contribution to the discussion but I am not sure that I understand what you are saying this can teach us.
It is a pretty old watch and 400mAh is quite a good battery capacity. So probably you don't have to care too much about it
No memory issue w lithium ion. You are thinking old Ni-Cad
Yes, it is best to charge lithium-ion batteries from 40 to 80 percent.
Manufacturers that use these types of batteries in their products know this too
For all we know they could be charging it using a method similar to the 40/80 rule in the background
You'll have to explain that to me in more detail. That Garmin loads the watch up to real 100%, you can see if you go into the service menu. The battery is charged to 4.35V. And that corresponds to the final charge voltage of a 3.8V battery as it is installed.
Garmin does not do 40-80 magic there. The battery is fully charged. Just as you want it.
There is simply no 40-80 magic of the manufacturers. And there is no manufacturer yet able to eliminate these chemical processes that negatively affect the battery below 40% and above 80%. Of course, manufacturers know how a battery works. But I am curious what you mean how they should solve it ;)
No, that is wishful thinking
No. The article is on lithium batteries and not nickle-cadmium. It even says so in the post.
I am not a chemical engineer like some of you seem to think you are, so I can not explain any detail about how garmin charges their devices. But I can say that they DO have actual engineers that figure all this stuff out.
The watch alerts you when the battery gets low, and the users guide says to fully charge the watch. I could not find anything in the users guide that says to charge it at 40 percent and only charge it to 80 percent.
some of you are way overcomplicating this and making people think that they need to follow this 40/80 rule.
I don't know about others, but I am not going to spend a thousand dollars on a device that claims to have this much battery life so I can charge it every day or two because some people think they are chemical/electrical engineers, and maybe think they know more than the engineers at garmin (who designed the device).
Follow the documentation and you will be fine.
Does this mean apple watch users should be charging their apple watches three times per day instead of once per day?...hahaha
Where did someone say that ? I said "You have a choice.
Garmin doesn't need engineers to figure this out. The chenical processes that happen in a Li battery are simply known. The technology didn't just exist yesterday.
I don't know how many thousands of dollars a tesla costs more than a Garmin watch. But I can tell you that Tesla only charges the battery to 90% in standard mode to conserve battery life. If you want to fully charge, you have to confirm that. I can also tell you that Garmin does not ask us how full we want to charge.
If you want to save the Garmin battery, stick to the 40-80 rule.
Or just don't do it.
No one here is telling you how to do it.
YOU HAVE THE CHOICE.
The Li batteries in the Tesla are chemically the same.
A word about the manual and the tips of a manufacturer: is it in the interest of the manufacturer if the battery lasts forever ?
What do you mean by "you have the choice"?! I heard that in the next firmware release, Garmin will enforce that. If user is not following, watch will provide electric shock at 80% then with every percent another one, stronger...
Oh, nice that this is finally being introduced. This has been an old suggestion for improvement.
