Actually having two issues.
First is the swipe feature only works randomly. It'll usually always work if I push a button first and then it'll scroll. At times it works perfectly. When it stops working then I can't even scroll down on a text message. I have then use the buttons. Like I said.. At times, it'll work perfectly.
Second issue is that I can't adjust brightness. I can get to the screen and it'll change when turning it up or down but then as soon as I go back to main screen, it's back to the stock dark setting it came with.
Talked to the tech dept and he was useless and quite rude. At the end all he did was open a ticket to which he couldn't expand upon as to what happens next.
