Pulse Ox and health snapshot
Hi,
If I set the pulse ox preferences to measure only during sleep, I'm not able to measure pulse ox manually or in the health snapshot.
I think that doesn't make sense, it should be possible to use the sensor manually (or in health snapshot),  even if it's set to measure only during sleep.
What do you think, is that behavior an issue or a new feature?
Stefan.
  • For me on f7x ss nearly the same. Pulse Ox wasn't working when sensor is set measuring during sleep in health snapshot but it worked with the widget/glance manually. Tried to set sensor the whole day but no pulse ox in health snapshot. After that set sensor to manually it works with health snapshot. Set back sensor to nightly and it is still working in health snapshot. Very strange
  • I also set on my F7x SS pulse ox measurements to be taken only during sleep.  In the morning when check the details I can see during sleep the watch was checking ox. Other than sleep time if I scroll to pulse ox widget/glance manually I can see when was the last time measurement took place. If I open the widget within 3' the message "MEASURING KEEP STILL" appears on the top of the screen and when it's done in brings the value of pulse ox measured. With health snapshot it works as well. I think this is how it should work with my current set up.
