Got a Fenix 7X Solar Sapphire (Ti Carbon Grey) yesterday, really quick delivery from REI btw. I have an Epix Gen 2 on order to compare.
Hardware
- It feels very light for a 7X. Running with it is not a problem in terms of a larger device. Note, I run mostly with an FR945LTE.
- Touch screen is very smooth and responsive.
- Display is more reflective than my F6ProS but differences between Corning DX and Sapphire/TouchScreen layers make a difference.
- Display solar ring is very noticeable. Distracting? Not really.
- Backlight illumination is easily discernible.
- Bezel / Case / Buttons - look and feel good. No issues with these buttons.
- Glass layer depression of the HRM sensor may tend to trap moisture on long runs or overnight if you have it on fairly tight.
- Noticed some skin irritation this morning.
- Will keep an eye on it and see if it is reproducible for me.
- Torch/Flashlight - very cool. Used it in cadence mode running last night. Foggy dark night in Oregon, having a little bit extra illumination is a plus.
- Red light is nice too for overnight hiking.
- Wifi connectivity is much improved over my F6ProS. It will sync easily with my mesh router, unlike my F6ProS or my FR945LTE.
- Heart Rate Sensor is not noticeably different from my FR945LTE (same sensor)
- GPS accuracy - will be testing that more this week.
- Need to test Pace without the Stryd.
- Sensor pairing - Power(Stryd), HRM, Kickr, etc. All work as expected.
- Bluetooth pairing headphones and music playback need to test.
Software
- Stamina - Very interesting feature for runtime feedback. Need more time with that.
- There are some Stamina related fields add
- Messages are reverse (black background, white text). Not happy about that.
- UI is responsive and extra drill down ability with glances/widgets is great.
- Sleep works as expected.
- Body battery consistent.
- Stress recordings consistent.
- Physio Trueup is doing it's job and syncing fine.
- Structured workout sync from What's Today's Plan and Training Peaks all worked fine.
- My running coach uses TrainingPeaks.
Fairly happy with the experience so far. Will also be comparing to an Epix once I get it.
Sean
