Wrong altitude calibration before start an activity
Good evening, I noticed this identical problem also in the Garmin Fenix ​​6X Pro. Maybe some of you have a solution or will be able to explain to me how to correct it.
Before starting my activity, the altimeter a few times inserts me the value that I had previously manually calibrated at home.
Obviously my activity was away from home. Today entered me at 314m (my altitude at home), when in fact I was at 1.460m.
Yesterday, however, still in the same area, immediately recognized the correct altitude.
During both activities, he still behaved perfectly, so the problem is only the initial calibration.
Automatic altimeter calibration was on in both cases.
  • I understand, but then the GPS confirmation shouldn't stay green.
    However next time, should it happen, I will try to see what happens with the calculated incorrect altitude and the auto calibration active during the walk.
    If I am at 1.460m and 340m is marked, using the DEM it should understand that maybe I am a little bit taller :)
