After an initially failed map upgrade that completed during the second attempt my F5+ running 13.0, GPS 2.7, Wi-Fi 2.5,CIQ 3.1.8 has become extremely sluggish during all map operations. I tried re-installing the maps using Garmin Express which finished without an error message and even did a complete factory reset yesterday. The problem remains, however: During booting, I am stuck for approx. 3min in the "Loading map" screen and zooming in and out during an active usually takes north of one minute.
It is a bit frustrating since so far the watch has performed quite well.
I don't think the factory reset clears out the map directory and suspect that I do have bits and pieces lying around from a failed install. What files do I need to ensure that I am using the Topo map and where are they located? Just in the GARMIN folder? How do I know which files are related to map information and can be deleted from the GARMIN folder? Is there anything else I can do to truly reset the watch to a fresh state?
Thanks for any help,
Chris
