If you either reset to default settings (prior known as a master reset before we updated the name) or use the unprompted reset holding all 3 buttons, your watch will fully reset to defaults.
You…
Along with cleaning the connectors, try this.
With the watch not connected, hold three buttons down (light, down and start buttons) for 15-20 seconds and try charging again.
I just finished chatting with Erica from Garmin Support Centre. The chat took less than 10 minutes and resulted in them sending me a refurbished watch, and I'll send in the defective one when I receive…
Mine wouldn't charge at ALL. I did your trick thinking it wouldn't work as there was no power left but it worked. Thank you!
Sorry, This post was a while ago but mine is the same, chages from PC but not wall adapter. Did you have the repair done and if so what was the fault? Thanks.
Thank you for this. Just tried it and it worked. Really helpful.
I just finished chatting with Erica from Garmin Support Centre. The chat took less than 10 minutes and resulted in them sending me a refurbished watch, and I'll send in the defective one when I receive the new one. So quick and easy...
Thanks for the great tip, CHARGING now and going well
