Pixel shifting protection (not working in AOD)
EDIT - This is not resolved, and I think I have really uncovered a glaring issue with the programming for AOD on this watch...  read on.
So, first I use the AOD on this watch.   But I decided that I don't really need (or like) the gesture mode when I am indoors (and that is most of the time).  I can see the AOD just fine and figured it would save even more battery (and screen life) by disabling the gesture mode.  (i.e. just let the dim AOD be on all the time and just push the light button to "wake it" to full brightness on the occasions I may need to see it in sunlight etc.).
However..
I noticed that when I manually trigger the display (using any button) that the watch face will shift a bit when it timeout.  (Pretty cool, and I am sure this is the pixel shift working).  Same goes when I activate gesture mode, once it times out it shifts the AOD just ever so slightly, if you look close enough you can see it.
Great.  However...
I may be wrong, but... I don't think the shift will happen in AOD, with no gesture mode (or manual trigger of screen).  So, this would suggest that if you use the AOD and DONT use gesture mode, then the screen is static with no shift at all day etc?
I would like someone (Garmin Chris maybe) to confirm this..
T
EDIT - For fun, I sat here and synced the Epix to my G-shock and watched for 6 min straight to see if by chance the AOD would shift every min, or every 5, etc.   and it did not.   Yet, the second I triggered the light button, it shifted.  So, unless someone can correct my thinking, it appears that you need to use gesture mode to get any benefit from pixel shift (which I think is terrible), as I don't want (or need gesture mode) would rather save the battery and screen from ramping up constantly all throughout the day.    This seems like a big oversight, unless the time interval is more?
To be clear, I would have fully expected the AOD to shift every so often, regardless of if gesture is enabled or not, or regardless of if a button is pressed or not. As it stands now, that does not appear to be the case and I am just burning in the same pixels for most of the day until night mode kicks in, or an activity is going on.  That is bad news.
  • Hi,
    My Epix Gen 2 shows burned in areas in The Display since a few time. I am using an Apple Watch since a few months in the office and my Garmin after work or on weekends.
    In the time when I use the Apple Watch, the Garmin lies on my desk. AOD is on and as you described, because of no gesture and no button press, I think pixel shift is Not working and caused the burn in.
    I use a standard Watch Face and I See parts of the watch face and even the first digit of the clock (I live in Austria - 24 hour setting- so the 1 on the first digit is present from 10am to 8 pm) burned in.
    So I think your theory is correct that pixel shift is Not active in these situations.
