I have had an Epix 2 since launch and have been thoroughly impressed with its GPS accuracy- which I used to complain about across multiple prior Garmin devices I had.
I always wait for a few minutes after GPS signal has been acquired and consistently get excellent results post run.
This changed since the betas leading up to, and including, the current firmware ie 8.21. An easy way to spot this is to compare the first couple of laps to the rest.
See an example below:
connect.garmin.com/.../8869884336
I use every second recording with all+multiband; I am also sending this message to Support. Anyone else seeing this?
