So I've been using the Garmin HRM Pro heart rate strap for my runs, but I'm still getting cadence lock for the first 3-5 minutes of almost every run I do. For example, when I first start running, it'll show my heart rate in the 160-170 bpm range (which is my running cadence at the time) instead of my actual heart rate. After a few minutes, the HR will drop immediately and be "normal".
I know this can happen with optical HR sensors (like the one on the watch itself), but I thought the HR strap would eliminate this. I know the HRM Pro is paired properly (ANT+) because I'm getting running dynamics for the entire run (even during the time when the HR is cadence locked). And it shows the HRM Pro listed in the sensors section in Garmin Connect after my activity.
Could it be that it is using the optical HR sensor on the watch at first and then switching to the strap after a few minutes? Or is the HRM Pro actually locking to my cadence (which I didn't think happens with the straps)? I do wet the strap sensors before putting on the strap, but maybe it's not picking up my HR right away?
