Need "auto" mode sleep schedule
Issue with Scheduled Sleep Mode Reactivating After Manual Exit
When using Scheduled Sleep Mode on the Descent Mk3, if I wake up early and manually disable Sleep Mode from the Glances or Controls menu, it reactivates shortly after — continuing until the originally scheduled wake time. This makes it difficult to fully exit sleep mode unless I modify the schedule. A manual exit should persist for the rest of the cycle or until manually re-enabled.
Feature Request: Please add an option to prevent reactivation of Sleep Mode once it has been manually turned off during the scheduled window.
  • On My FR965 I find if I go to one of the widgets that shows "sleeping" on the widget  (I forget which ones do) and then select it and from start button select end sleep it works.
    I think the othere way temporarily just exits sleep mode and then goes back as as one is still in the sleep schedule
  • Update June 5, 2025:
    Our engineers are aware of a concern that may allow the watch to reenter Sleep mode, after this has been ended. They are anticipating a fix for this, to be released as early as mid-late June.
    In the mean time, sleep mode will end when scheduled. You can also avoid this reentering sleep mode by recording an activity.
  • Similar issue when the watch enter sleep mode in the first place.
    E.g, it's 11pm, watch enters sleep mode based on schedule but I am still awake and disable sleep mode manually. After a few minutes it might go back to sleep.
    This bug has been reported for years.
