Hello Descent Mk3 users,
We have fully released system Software 19.34 for the Descent Mk3/i/s.
Change Log
[In-Dive Change] Added ability to send and receive additional SubWave messages, with compatible Descent T2.
[In-Dive Change] Added ability to send and receive SubWave messages direct to/ from another diver (in addition to existing group messages).
[In-Dive Change] Added ability to respond to a Subwave Message when a message is received
[In-Dive Change] Improved apnea in-dive data screen layout
[In-Dive Change] Added display of stopwatch timer to apnea in-dive data screen when active
Added ability to specify a set of favorite/quick access SubWave messages
Updated the default End Dive Delay to 5 minutes. This only takes effect if you reset settings.
The SubWave versions have been incremented to account for the new SubWave features, so you may see a notice on the pre-dive check. Please update your Descent T2 devices and other watches to take advantage of these new features.
Improved Gauge Dive lockout behavior. Lockout will now occur after spending at least 3 minutes at or below 15ft in a Gauge Dive, rather than after 30 seconds
Improved stability when pairing multiple tankpods
Improved SubWave messaging stability and reliability
Brought in the latest updates from Epix Pro Gen 2 including:
Added courses and saved locations to device backups.
Improved heart rate zones to allow setting by BPM.
Fixed potential shutdown when modifying heart rate zones using Garmin Connect Mobile.
Fixed potential shutdown on boot.
Fixed potential increased battery drain after having done an activity with incident detection enabled.
Fixed issue with trolling motor pairing sequence.
Fixed issue with maps showing doubly thick lines in some cases.
Fixed issue causing basecamp to fail to recognize the device.
Added Garmin Share app.
Fixed issue causing activity calories and the number of activities to reset to 0 after completing Health Snapshot.
Fixed issue causing Garmin premade workout animations to be missing.
Fixed issue causing missing pan/zoom on map during navigation for find my phone.
Fixed issue causing Outdoor Maps+ downloads to get stuck at 0%.
Fixed issue that could cause Connect to fail to display which course was used for activity.
Fixed issue when navigating the watch would the distance to the destination in feet/meters instead of Mi/KM.
Fixed issue where the golf glance could display a 0 value when using stableford scoring.
Fixed issue with a missing keyboard switch icon in some languages.
Fixed issue with strength workouts rounding the weight to the nearest whole number.
Fixed potential issue with connection of external bluetooth sensors.
Fixed potential issue with GPS track during snowshoe activities.
Fixed potential issue with the cursor on the golf map.
Fixed potential screen distortion on the watch face.
Fixed potential shutdown after receiving a flag measurement from a Z30.
Fixed potential Wi-Fi lock up when requesting software.
Fixed issue causing delay to the flashlight turning on when using a Connect IQ watch face.
Fixed issue causing loss of elevation data in a multisport activity that started with swimming.
Fixed issue potentially causing 0 distance for a pool swim activity.
Fixed issue that could cause sleep to not get recorded.
Fixed issue where nautical units were not applied to the auto lap setting.
Fixed issue with incorrect prompt saying FTP was updated.
Fixed possible shutdown when using Around Me to search the map.
Fixed potential shutdown when using the Round Trip Routing feature.
Fixed crash when choosing Pan/Zoom on Apnea map.
Improved race time predictions.
Improved auto climb sensitivity in climbing activities.
Improved map controls.
Improved messaging for course and location backups when paired to the Explore App.
Updated translations.
Misc. bug fixes and improvements.
