T2 transmitter orings
Hi,
I'm having some oring issues with my Descent T2 Transmitter and was hoping I could get your help, since Garmin Support is literally ignoring me.
T2 bought at January '24, made 50 dives since then all with transmitter attached on a short HP hose using the supplied flow restrictor. Unfortunately, the T2 uses non-standard size of the spool and the orings making it extremely hard to service. My problem is not only with the size, but with the frequency of failures of this oring. I had already 3 failures, one of which was unfortunately pretty deep and required emergency ascent.
I have not identified any potential reasons for my orings failing - I've lubricated them with proper silicone grease before installation, they sit inside a T2 unit, so nothing external can be twisting/scratching it etc. First one lasted like.. 20 dives, second 10 and third not even 5.
Here's a result of the failed oring, for curiousity ;-)
https://youtu.be/0BzBYfTtMbg?si=1WWHBBDbgvgvo9YV
here is the specification:
https://support.garmin.com/id-ID/?faq=LvVEp0czyc5xNpfoGzAbE7
As you can see, the spool uses:
Large Side
  • Size: Internal Diameter 3.30 mm x 1.00 mm
  • Material: 70 Durometer Neoprene
Which is nearly impossible to acquire and Garmin only offers a full set of flow restrictors for ridiculous price.
Should I suspect it is transmitter, spool or something else damaging my orings?
Regards,
Adam
  • Hi there.
    Did anyone have the same issue and/or do you have access to those specific orings anywhere on the market?
    I have a local shop specialising in orings in general and their opinion is that '70 durometer neoprene' that has been specified in Garmin documentation is durable till 160 BAR. This is interesting, as these orings are in HP port of the regulator and the working pressure there is much higher.
    What are your thoughts?
    Regards,
    Adam
    P.S.
    Despite having dozen of emails with Garmin support and a promise of "some solution' and spare parts sent to me I am still waiting ;-/
