I've noticed that Mk2 and Mk3 series (not sure about the original Mk) use a different charging cable/connection than the most recent Fenix/Forerunner watches. Is there a reason for this?
Thank you in advance,
Kind regards
Sergio
Kind regards
Sergio
yes, thanks... while I understand that water-tightness is fundamental I tend to believe the main reason may be to make it easier to clean, removing salt and other things...
I doubt sealing is the reason. The other watches like the Fenix are also rated to 10 atm (I had the Fenix, then the Mk1 and Mk2i). My purely speculative guess is that it is for a more secure charging (and…
I do not know for sure, but I would tell that it is to assure the water-tightness. It might be challenging to properly seal the pins of the smaller connector, under such high pressure. It should be also easier to clean the bigger contacts, remove the salt deposit from them, and to avoid short-circuits between contacts when wet, thanks to the larger gaps.
but I would tell that it is to assure the weathertightness
Yes, it would make sense that the different style clip charger is to ensure the 100m Dive rating (Mk3 is now 200m).
The same clip charger is on the Mk1 and Descent G1 series as well.
err, sorry for the typo - should have been "water-tightness"
err, sorry for the typo - should have been "watter-tightness"
all good, we get what you mean
I doubt sealing is the reason. The other watches like the Fenix are also rated to 10 atm (I had the Fenix, then the Mk1 and Mk2i). My purely speculative guess is that it is for a more secure charging (and connection to a PC for USB/charging) when the watch is on a dive boat in ocean conditions, for example when jostled around at night in tight quarters, complicated messy conditions, as most dive boats are, having a secure clamp is more secure than the smaller Fenix-style connector. Just a guess.
