Hello MARQ customers,
Our next beta version for the MARQ Series is now available!
The beta below is not compatible with MARQ Aviator.
Instructions for installation are available below the change log on the above page.
This update does bring in a modification to the software update process: If you load 20.42 to your device, disconnect, and choose to install later, it will delay the installation 2 hours and you will then get a prompt and a 30 second countdown. This process is only available if you are updating from 20.41 to 20.42.
20.42 Change Log Notes:
- Improved robustness to nightly altitude calibration.
- Fixed altitude flatline bug.
- Fixed potential issue on device boot.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 5.30
Sensor Hub: 11.01
ANT/BLE/BT: 6.15
Wi-Fi: 2.60
Please note, the beta updates released on these forums are not compatible with APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the MARQ you have in the subject line.
